Choke for a Holley Carb
tk1891
I recently purchased a holley carb for my engine. It came with a red wire for the choke. Do I need to wire this up? The old carb doesn't have one. 1988 305 V8, w/4 brl carb.
Thanks for any suggestions.
TiredoleBoy
Re: Choke for a Holley Carb
I suppose it has a heater element in the coil cap for the choke? I never used them I just adjusted the choke to wide open and left it like that. Just let the boat warm up a bit prior to moving.
But should you wire it up. It should go to a 12 volt keyed source for power.
tk1891
I never used them I just adjusted the choke to wide open and left it like that. Just let the boat warm up a bit prior to moving. But should you wire it up. It should go to a 12 volt keyed source for power.[/QUOTE said:
Thanks, that's what I figured just double checking myself
HT32BSX115
Yeah,
I did the same with my 454.
I adjusted the automatic choke so that it is open all the time and disconnected it altogether. I don't boat in cold weather. I just let the engine warm up a bit and it's fine.
After it's been run during the day it's just not a problem.
Regards,
Rick
