Choke Plate Closing & Carb Dumping Fuel (leaky carb float)
bigskiohio
Re: Choke Plate Closing After 1 Hour **PICS ADDED**
i have to throttle mine up too, even when warm then i return it to idle when it starts. mine idles good with lever down but i adjusted my throttle cable recently.
does yours idle? cold and warm?
gene8084
There's something wrong here. While disabling the choke is an option, knowing it used to work, I'd go back to the drawing board. You need to find the assembly and adjustment instructions take it a apart and start at the beginning.​
Why deal with throttling up to start, that's what the choke is for? Let it do the work for you.​
smartwork
Question: At the one-hour mark, is the tension on the choke plate the same as when the engine was cold? More? Less?
Reading through the thread, one thing stuck with me: You said that it was after a length of time at WOT and that you probably couldn't replicate it on the muffs. To me, that means that something has got to be heat-related... maybe even extreme heat.
I don't know if this is possible... but, here's a hyphothisis. The reason the choke coil contracts and expands with temperature is because it is made from two materials that contract and expand at different rates. When the choke heats up, that difference causes the coil to contract (which allows the choke plate to fall open with gravity acting on the plate and linkage). Well... (here's the part I don't know is possible)... what if the coil got SO hot from running WOT that the difference in those two materials reaches a plateau (maybe from defective coil), equilibrium, or reverses. I don't know if that's possible, but if it reaches reversal, the coil would then start expanding again... pushing your choke closed.
Has it done it at any time other than when the engine has been run hard?
smartwork
...continuing on my last post just above, here's another idea. Again, thinking it may be associated with WOT... but maybe not the heat of WOT... but the wind it creates. In photo #3 above, the heat-riser tube looks a little pinched off as it rests on the black hose.
Do you think that it's pinched off enough to reduce the flow of heat, and then when you're going WOT there's enough air circulation through your engine compartment that you're actually now COOLING the choke which allows it to close. Without the aid of electric choke, it may not take much air to cool it back down. WOT over a length of time may just do it. Maybe before the engine work, the heat-riser was routed on the other side of that hose which prevented it from being pinched closed (or reduced).
HT32BSX115
I think you might be making this a little too complicated......
You can answer your question by heating it up...... Grab that little "spring" in a pair of needle nose pliers and hold it over a flame and see what it does.
If the tube was pinched off it probably wouldn't allow the "spring" to get hot enough to even open the check at all.
But if it is, you probably need to replace it.
myoldboat2
Thanks to all of you, I really appreciate the efforts people make on this forum to help each other out. I will try to answer all the questions.
HT32BSX115
> Good clear pictures!!
Thanks!
> You didn't indicate where and when you boat, but I only boat in fairly warm weather. I have an electric choke on my 454, had one on my 460 and when I had the 150 Mercruiser (with pretty much the same carb as in your pictures) I either disconnected the (electric) choke or adjusted it permanently open. Unless you're in pretty cool weather, you might be able to just go without it.
I agree. I wired the choke plate open as Charlie suggested, but it doesn't start well when warm--I have to put in throttle. I assumed this was to enrichen the mix because of the wide open plate, but now I'm not so sure. When I get a fresh load of fuel maybe we'll see a change.
I also only boat in fairly warm weather.
> Now having said that, your choke is a pretty simple device using that little piece of copper tubing to route heat from the manifold up to the bi-metallic "spring" (electrically heated in mine) you show in your picture. The spring when cold is adjusted to close the choke and when it warms up it opens the choke and takes the fast idle detent out of the picture....
Yes.
> You're obviously not getting enough heat up the tube to warm the "spring" and open the the choke once it gets running or the linkage is bent/binding and the spring cannot move it.
No, I don't think so. I've watched it three or four times now when cold, with the flame arrestor off. When cold, it starts great with the usual method--about three pumps of the throttle, leave the throttle open to maybe the 1800 rpm, turn the key and she starts immediately. The choke plate was being held lightly closed as it should be, and then it opens as the engine warms--rather quickly, in like 30 to 60 seconds actually. Then after running hard for about an hour, the plate is pulled tightly closed and the engine won't start with less than about full throttle, which engages the unloader to open the choke plate. HEY, this reminded me of something I will put in BOLD at the end of your questions!
> The tube might be plugged or the port on the manifold it's connected to is rusted/corroded shut or it's plugged with other debris. That should be exhaust gases going thru the tubing so the little housing that holds the "spring" also probably has a small vent to allow those gases to escape so that there's a "flow" of (hot) exhaust gases across the bi-metallic spring.
When I had the tube off I blew through it--wide open, no debris. There might be debris in the manifold port, but the choke gets heat quickly enough, so I don't think so. Now the choke housing vent is something I have NOT looked into, and I think you're onto something (bold below).
> Also, it might just be adjusted incorrectly.
Perhaps, but it was set to the same setting it was always at, and I've played with other settings with no help.
NOW HERE'S THE THING YOU REMINDED ME OF:
I apologize--I don't think I mentioned this before, because I forgot all about it. When I had the engine out and was getting ready to put it back in, I noticed the choke housing was loose! I mean, actually wiggling on the carb. I took it apart and found how to tighten it. After removing the metal baffle plate, I could access the two Phillips head mounting screws. I tightened the choke down and reassembled it, adjusted as it was before.
It was so loose that there was a small gap between the choke housing and carb--making a good vent, I suppose. So maybe I no longer have a working vent in the choke housing. Is it possible it gets so warm that the coil spring wraps once around, and the tang slips over the plate lever? It doesn't sound possible to me, but I can't find another explanation for why the choke plate ends up tightly closed after an hour of kids skiing.
Where is the choke housing normally vented?
bigskiohio
Until now I've never had to throttle it up to warm start. I could just leave it in neutral at idle speed, turn the key for about 1/4 second or less and it would start up at idle speed.
Now it does this:
Cold -- As above, I have to pump it about three times and then start it with some throttle in when it's cold. I've always had to do this--and I don't mind. I leave it at 1500 rpm or a little more for a few minutes and it gets up to 130 deg. Then it idles great.
Warm -- It will not start at idle setting. I have to start with throttle open pretty far. Then it takes too much cranking, like it's trying to start. Then it finally sort of starts, then the rpm's climb slowly while it "clears its throat" or something, then it gets up to around 1800 rpm or more and the running smooths out. THEN it will idle just fine. I really hope this is a bad load of gas, but I don't think I'll be that lucky. As I've said, I now think I have two separate problems--one causing the choke plate to go tightly closed when really warm, and the hard starting when warm. Both are new. They may be symptoms of the same problem, or not.
gene8084
I agree.
The Mercruiser Service Manual on page 4B-9 lists only this:
AUTOMATIC CHOKE ADJUSTMENT
Normal setting of the choke is such that scribed mark on cover is in line with long case mark on choke housing casting.
No adjustment of fast speed is provided.
Page 4B-4 and 4B-5 show how to disassemble the choke. I've done that, but have never removed the choke piston and linkage from inside the housing. Page 4B-7 covers choke reassembly (one short paragraph for what i've done).
I also have a Clymer manual (I know, I know...) that actually does a better job of describing the choke adjustment.
I agree with that. When warm, I want to just turn the key to start at idle. With kids wakeboarding and skiing, the engine is going off and on all the time, and I want to know it will start when a kid is out in busy water waiting to go.
smartwork
It is much, much more. When cold, it is where I adjust it to--lightly closed per the manual (some say to use an 1/8" drill bit, that's fine, this isn't the issue). Once it's hot and the plate is closed under a lot of tension, I'm pretty much stuck until I loosen the choke cover (it spins hard) and reset the choke setting. So I can't say what happens if I just let it cool once it happens--I needed to get back to the dock!
I would've said no, that the engine is staying at about 135 to 140 deg tops (usually 135 deg, I'd say). But, per the discussion above, I think the inside of the choke housing may be getting very hot. I don't understand how that's supposed to be vented.
Yes, I've wondered if my choke coil is bad. Is there a test, like for a thermostat, where you can put a choke coil in water on a stove, and it should uncoil a certain amount at certain temperatures? I guess I have to get the coil from an auto parts store, if I want to pop in a new one to test it. But it looks and feels good, and I think it's related to me tightening the choke housing onto the carb and now it's not venting to release the heat (?).
No. This weekend was the first time it happened. It was the first time I was able to run the boat on the water since I had the engine out to replace the coupler. Except that it was on the water for a few minutes the weekend before, when I trashed the impeller and the engine got to 190 degF. So I've replaced the water pump and impeller since then. Cooling for the engine is now good, 135 degF running temp.
Today when I first looked at the carb, the plate was actually closed tightly. It probably went into that position on the way to the launch to be put on the trailer and driven 3 hours home.
All I can think of is that:
1) tightening the choke housing closed the venting; or
2) I bent something in the linkage when hoisting the engine (I don't think so, but maybe).
(I know, loosen the choke housing and try it again... the boat is on a trailer here at the house. I can't get back on the water for another 2+ weeks due to other commitments to my kids. I'd love to have both issues--carb closing and hard warm starting--resolved for next time, if possible.)
Any new thoughts?
Thanks!
myoldboat2
I think just the insulation on the riser tube is pinched. I slid the insulation up and down and it didn't hang up at all. And I blew through the tube without any trouble--no blockage.
The choke isn't cooling down and pulling the choke plate. When the plate is pulled tightly closed and I loosen the three clamps around the cover plate, it spins to loosen. It's not clear to me what's causing the tightness.
myoldboat2
Yes, I should do that.
It seems to work as it should until I've run hard for an hour or more. That's what I don't understand.
gene8084
I'm not sure photo #3 indicates a collapsed tube. It's a solid copper tube with a shield right? Certainly worth confirming it's not crushed, but doubtful.
What about the PCV? Could a failed valve cause undue pressure or free flow at WOT that's preventing the flow of air through the choke warmer tube.​
myoldboat2
I don't think the choke is closing because it's getting cool. Still not sure what's causing it to pull the plate tightly closed. When I take it apart, it's very warm in the choke housing.
myoldboat2
It was not bad fuel. We siphoned all of the old fuel out, got 10 gal of fresh 93 octane, and it acts exactly the same.
JustJason had a theory in this thread:
http://forums.iboats.com/showthread.php?t=351142
...that a carb might be dumping fuel on shutdown. He talks about looking into the throat while shutting down. Will I be able to see if it's dumping fuel?
It's really starting strangely. It starts but runs lousy. Say I have the throttle at about the 1500 rpm setting. The engine runs lousy at lower rpm, then slowly climbs in rpm, reaches 1500 or so, I may have to increase it a bit to about 1800 rpm, it slowly smooths out. All of this in neutral on muffs. It might take 30 seconds for it to fully smooth out. After that, it idles great, accelerates great, drops down in rpm great when the throttle is pulled--acts normally.
Is my carb probably hosed? I can pull it and have it rebuilt again.
:confused:
TowRoper
While I'm considering going chokeless...
does anyone have a theory as to why a choke would start closed, open with warmth, and then close tightly with lots of coil tension once the engine is fully warm (1 hour of skiing with lots of WOT)?
Do these bimetallic coils ever go goofy?
they sure do after yrs of being pulled 2 different direction ant thin metal does wear down and fail and in some cases reverse on them selfs
JustJason
Its entirely possible you have 2 different problems with the carb. The rough running you speak of does fit the bill of having a leaking carb, because the engine is hesitating/stumbling trying to clear the flood out.
As for the choke. The little piston in the choke horn stick sometimes. Pull the horn off and pull the piston out and make sure its all clean before you put it back together. That bimettalic coil should be pushing the choke open. You can try throwing the coil in some hot water (does not have to be boiling, you don't want to melt it) and see if the coil expands and stays expanded for a period of time.
myoldboat2
Re: Choke Plate Closing After 1 Hour **WASN'T BAD FUEL**
Thanks for the quick replies, guys. I will try to do these tomorrow afternoon (after I see how Favre does with the Vikings and before I watch the Packers!). I'd rather be boating but my kids are busy with commitments. :(
jtybt
Could be sticking float valve/float too high or even ruptured fuel pump diaphram. Ruptured diaphram would have gas in the vent overflow tube to the carb.
Sticking float may be dislodged by rapping carb with plastic screwdriver handle.
myoldboat2
OK, I think I found the problems -- (1) the choke isn't acting right (found some things but still not sure why), and (2) the carb is dumping fuel at shutdown.
First the choke...
I took it all apart and soaked and brushed all the parts.
Why does the choke piston have ring grooves but no o-rings or rings?
I tested the choke coil with hot water. Looks good to me.
I believe the vacuum port is the lower left hole. It looks like my gasket was shot.
I think I may not be using the choke at all. With the coil adjusted correctly, here is how it looks. For cold starting I pump the throttle three times and set it at about the 1500 rpm setting--because of that (?) the choke plate pretty much opens immediately. So once I get the fuel dumping fixed, I'll try it again without the choke plate like Charlie recommended.
So I think I understand how the choke is supposed to work. When cold, the coil pulls the lever CCW and holds the choke plate closed. When cranking or running, there is vacuum in the carb, and the vacuum draws the warm air up through the small tube into the choke housing. The vacuum also pulls the choke piston deeper into the small cylinder in the choke housing casting, which tries to pull the choke plate open, against the tension of the spring. So as the spring warms and the lever is allowed to move right, it will move right due to the vacuum pulling on the piston and gravity pulling on the offset linkage.
My gasket is shot, so the vacuum probably isn't right. That probably has something to do with the choke acting weird when the engine is fully warm. I will either replace it or have it replaced if I have the carb rebuilt (see below).
myoldboat2
OK, the carb is dumping fuel onto the throttle plates at shutdown. The front barrel drips about 2 drips a second. The rear barrel drips 5 to 10 times that--almost a stream. The fuel puddles up, I don't know, maybe 1/16" deep, and I think runs down around the throttle plates. This is definitely the reason it starts so hard and takes a while to clear up.
In the other thread I linked to above, it says the only solution is to rebuild the carb--is that the case? If so, I'll pull it Monday and take it in. My fingers are too big for those springs and things. I looked it up--I had it rebuilt in Spring of 2006. Is it common to have problems within 3.5 years? I got lucky and went a long time before that rebuild.
If the fuel dumping can be fixed by a "partial rebuild" that's really easy, I might try it.
Charlie, I did rap the carb with a screwdriver handle, no change. I don't know where the overflow tube is to look into it.
Let me know if I should call the carb shop. Thanks.
littlebookworm
Re: Choke Plate Closing After 1 Hour **DUMPING FUEL AT SHUTDOWN**
I've been reading through your post and the responses and have been examining the photos. In my opinion you've got three separate, but related, problems: the rough running, the choke malfunctioning, and the fuel dumping. The loose choke housing, which you tightened, had previously led to gumming of the choke piston and the system, The dumping of fuel is probably caused by a sticking float or needle. The rough running is probably caused by some gum build-up within the carb passages. These are not unusual problems with engines which are not run all the time, such as a boat's engine. I'd recommend a full carb rebuild with a good soaking in carb cleaner. I'd also suggest you check you fuel filter(s). The e10 gasoline is causing all kinds of gumming problems for boat fuel systems. Good luck and let us know the final result. Hy
myoldboat2
I'll check the fuel filters. I repalced them when the engine went back in a month ago, but you never know.
I found this in a carburetor article:
I'll try tapping again.
Is it worthwhile to run some fuel system cleaner through the carb? More concentrated than usual, I'm not going to run 10 gallons of gas through on the muffs. I've read of people mixing fuel system cleaner with a gallon of gas and then running that through. If it doesn't work, I'll be pulling it for a rebuild anyway. The fuel system got a treatment of Techron earlier this summer, but there's been multiple tanks since then.
lbw, the rough running and fuel dumping are related, I think. It only runs rough after starting warm, i.e. after the carb has been dumping fuel. After about 30 seconds or so it clears the excess fuela nd runs well.
By the way, I've always used CD-2 lead substitute. It' never caused a problem before, I doubt it's causing the problem but who knows.
jtybt
If you don't have a clear plastic tube from your fuel pump to the carb, you may have the older fuel pump with a glass bowl. Gas showing in either the plastic tube or glass bowl means you have a ruptured diaphram in the pump.
