UtahBoating
Thread starter- Joined
- Dec 8, 2008
- 102
Not sure what I did. I finally got this motor performing the way I wanted and I messed something up.I decided to pull the carbs for a good cleaning and new gaskets I ordered. Took them off no problem according to the service manual. Cleaned and reassembled. Put everything back together. When I was putting the final fuel hose on I touched the battery cables by mistake and it sparked at me. I normally disconnect the battery and I just plain forgot this time. The choke will not close when I push the key in now. I have power at both sides of the circuit breaker according to a test light. I also have spark and the motor cranks just fine. I found a fuse panel under the dash and they are all good. There are some inline fuses off the battery also good.
What is my next step?
