Hi,
Today I started the engine, mercruiser 165HP from ‘70, for the first time since I bought the boat.
Carb has been rebuilt. And still operating the choke manually
I did put the choke in full closed position. Pulled the throttle 2x to inject some extra fuel.
Engine started almost immediately (me happy!!). After about 45sec I did shut it down as no cooling water was connected.
Before calling it a day I wanted to start it one more time for a few seconds.
Again had choke in closed position.
BUT I couldn’t get it running again. Tried with some extra fuel, no solution.
Only after slightly opening the choke valve it started again.
Question:
Should I better set the choke slightly open as a default position?
Or is there another reason for the starting problem that I “bypassed” by opening the choke slightly
PS: during the few seconds I let it run, it was obvious: as soon as I forced the choke to “full close” it would start to stumble towards stopping.
Question:
