choke
OBJ
Moving to Johnson/Evinrude forum.
Mike...if you haven't regestered with iboats, please do so.
sprouticus
Re: choke
mike said:
I Have a 1989 Evinrude 120hp push choke at the key any ideas what would cause it to not work?
I'm not an expert, but seems to me that the choke is engaged b a solenoid. If it is not working than I would have to say your solenoid is shot.
BoatBuoy
Re: choke
Solenoid is shot, keyswitch is faulty. Run a jumper from the positive(+) terminal of the battery and touch the terminal on the solenoid. If it actuates the solenoid, then there's a fault in the keyswitch circuit somewhere.
tashasdaddy
Re: choke
check the manual choke on the engine. all the way in is off/disabled. 1 click out allows the solenoid to engage the choke , all the way out is manual choke. not un common to get push all the way in.
