Choke
lmannyr
When should I see the choke closed? I have never seen it closed. Not when the engine is started cold or warmed up. With engine cold, I pump the throttle 4 times, and it starts right up.
I'm obviously not a carb guy... Again, never seen the choke closed. How do I check this?
thanks!!!
JustJason
Re: Choke
it should be closed when the engine is cold. If your in florida and its 90 out, but the motor is cold, the choke should still be mostely closed.
Don S
Re: Choke
They are supposed to be closed when cold, and open as the engine warms up.
Why yours is open ????? Who knows. Broken, adjusted improperl, wired open by previous owner.................
Since Mercruiser never used Holley, hard to say how to fix yours or how it should be.
Fishermark
Re: Choke
I guess the saying comes to mind - "If it ain't broken, don't fix it." ;)
If you are looking after you start up the engine, it may already have opened.
If it is open even before you start the engine, but it still starts with no problem, then I suggest leaving well enough alone.
lmannyr
Re: Choke
I guess I'll leave it alone. :) Starts every time after a few pumps of the throttle.
Thanks!!!
Aviator5
Re: Choke
if it starts and runs cold with choke open, the mixture maybe set too rich.
lmannyr
Re: Choke
Saving fuel is always a reason to check things out. Oh boy..
lmannyr
Re: Choke
Yup, max throttle 3-4 times then crank. I'll recheck again later today if the choke is closed before I start.
lmannyr
Re: Choke
Just checked......choke NEVER CLOSED....but again...4 FULL pumps...and it cranked right up.
SixtySevenGT
Backed off ?
Backed off ?
Usually if it has an Electric assist on it after a few hours or years the Electric heating coil burns out so people just lossen the screws and back them off.
Most people operate there boat in weather warm enough they don't need one.
I fixed mine becasue my 454 is a little cold blooded.
1995 Sea Ray 220 OV 7.4 merc.
