choosing the right boat winch
Rinker85
Hello,
I have a 4500 Lb boat on a roller trailer. What Lb rating winch should I get?
Thanks
dingbat
If you do the math you’ll find you need roughly 4,200+ pounds of pull.
Not going to get there with a hand winch without going to the gym a couple times a week
My boat is of similar weight and it just about stalls a 4,200 pound electric winch. Really struggles the last two feet
tpenfield
Manual winch ??? or electric ???
Roller trailers are easier to winch up than a bunk trailer (which can need a lot of pull) a 2,000 lb rating should be OK . . . the more the better (3,200 lb ?) and the winch should do a better job and last longer.
Lou C
Consider trying a 2 speed winch, the “lower” gear ratio gives you a good deal more mechanical advantage.
