chould this be a problem
DAN M VAGOS
first off thanks to all of you i love iboats you all give great hellp . now for my problem i have some engine running problems with my 89 force 50. the engine just started giving me some problems. there a some wires cuming out from under flywheel i think yellows and some browns there are 2 brown wires with a ? color in them that are diconected and cant be fixed i would like to know are thay for battery charging because the engine runs. thanks all
tater76
Re: chould this be a problem
Brown is likely from the trigger, is it running well? A picture would help greatly
roscoe
There should be no brown wires on a 1989 50 hp motor.
THere should be 2 yellow wires that connect to the terminal strip, then on to feed the cd module.
Also 2 green with yellow stripe that feed the rectifier, to charge the battery.
Guessing that someone has used some non original parts over the years.
DAN M VAGOS
ok but it does run so it must be the charging wires and im 99% that thay are brown will thay cause a problem
bentle
Well test at the battery and see if its charging. Worst case is leaving you dead in the water somewhere with a dead battery. If they are charging wires then reconnect to rectifier. Test battery again and make sure your not over charging.
