Chris Craft front engine mount
kenglund
I have a 1987 Cavalier with 3.0 GM engine.
See photos at: http://s862.photobucket.com/albums/ab187/rooooger/boat engine mount/
The front engine-mount bolts holding the mount to the boat frame will not tighten. I didn't want to remove one of them until I checked with you experts so I don't know if the bolts are held in with a nut or if they are lag bolts that don't use nuts. I can't see any access where I could hold onto the nut while I turn the bolt. I'm not sure if the mount sits on a solid beam or if it is hollow. Any info or suggestions would be GREATLY appreciated. Thanks!
