Re: Chris Craft, input wanted?
So I got the short block back Monday afternoon, started putting it all back together...Had to to work Monday evening, so progress was thwarted. Had to work 0900-2100 on Tuesday, so Once again, progress was thwarted...Luckily I got off at 1830 so I was able to get in a few hours of wrenching after the kids went to bed.
Woke up Wednesday morning and had to take kids to school, go to gym and show some houses to my retired Chief. As luck would have it, he had a engine hoist and I was able to borrow (this saved me the drive to the buddies shop with a fork lift and waiting until Friday evening to get the motor back in!) I finished the assembly, added oil and switched from engine stand to hoist for the flywheel, drive coupling, shield and starter. Backed the boat in the garage and installed. While I had no help, It would have been much simpler with 2 people...lowering, aligning, pushing, etc...
The motor's in, and all connected, as of 2000 last night. Going to the local boat shop here and have the mechanic check alignment (cheaper than buying the tool, at this time). I should note: I placed the engine mounts back on in exactly the same way...no adjustments were made, so I'm hoping all I need is an alignment check ($10.00), if it needs more then I'll order and alignment tool and adjust myself.
Once I have the drive back on then it's a earmuff test and possibly a water test tomorrow morning. It's supposed to snow Friday sometime, so I'll have to winterize, but at this point that's a 30 minute job (new oil, new sea water impeller, plugs and fuel stabilizer all done)
Oh and another ~$130 for miscellaneous (Oil, filter, Zinc additive, chain, tools, etc...)
GRAND TOTAL: ~$2,000ish (only interior left, $1,000)
~Brett
P.S. I should mention that I have no left over parts, except 2 wiring harness hoops (one smaller and one larger) I'll put them on once I figure out where they go!! Not mission critical at all!
