Re: Chronic overheat 1990 150 XP Evinrude
In the case of the picture that I posted above, the old deflectors have partially blocked the passages that should be open. The deflectors on that engine need to be replaced and the passages clened where the blockage (probably calcium) is obstructing the flow of water.
I have marked up and expanded a diagram from a Seloc manual; if you look closely you can see the arrows that show how the water should flow with the deflectors properly in place in a V6 crossflow engine.
Is the purpose of the deflectors to maintain unidirectional flow around all the cylinders and drain out at completion at the other end?? When someone stated that cleaning the water passage ways, does that meaning a manual scraping around the jackets??
Sorry, I have no intentions of hijacking this thread, but since it is somewhat relevant to subject at hand I thought I would ask. It is funny, but none of the service manuals that I have purchase, discuss water deflectors or maintaining patency of the water passage around the heads.
Pardon the interuption Lizardo.
