chrysler 105 w/magnapower II. how to test triggers and cd module?
challauer
Just like the title says. I got the flywheel of the 105 and the 55 parts motor. Interchanged the 2 and still no voltage or spark to the top 2 coil packs. What the heck do I need to do? Is there a way to test if the cd module is good/bad? Or how about the triggers? Please help im in watertown sd for 1 more day...
Nordin
Re: chrysler 105 w/magnapower II. how to test triggers and cd module?
The MAG II ign. is a little bit tricky to troubleshot. Outboardignition.com has a troubleshotchart for MAG II.
I bet your CD module is bad or the capacitor. They are the bad parts in that ign.system. First charge the capacitor by turning the flywheel with the starter. Ground the T1 terminal at the CD module with a tip from a screwdriver to the flywheel and then do the same with the T4 terminal. If you have spark when grounding at both the CD module is okey, if one fail the module can be bad. But you have the hole troubleshot at outboardignition.com.
challauer
Sooooo... according to outboardignition.com it says I would have a bad stator?? Ive found stators on ebay for a pretty penny but ive never even seen anything that even looks like what im seeing pictures of. This ignition sucks alot but cheaper to buy parts motors than buy a new one w the same horsepower. Will post another thread with pictures soon
