Kevin60181
- Joined
- Jun 30, 2012
- 44
I picked up this outboard a few months back from a Demolition Sale, house being torn down for new construction. See demo-pro.com for details.
I?ve been putts?n with pulling the flywheel on & off for months. Some butcher stripped out 3 of the 4 holes, and broke off the other bolt.
The other night I decided to drill 3 new holes and taped them. Like on an Evinrude outboard.
BAM! That flywheel came right off. First thing I see is the Blue wire from the condenser is rubbed clean down to the wire from hitting the magnet in the flywheel. (Bad Tune-Up)
I found the part here on Iboats.com # 18-5241
I have a number of questions????
12.9 HP, Model 122HD, Serial # 5156
What year is this?
Where can I find points?
Would that short from the condenser have damaged the coil?
I haven?t tested the coil yet with a VOM, but will.
The Impler number?
And the Big One!
How can I set this up, to set the points with a VOM meter like on an Evinrude outboard engine?
That?s just such a sweet way to fine-tune the points!
I haven?t even tried to start it, do to the fact I can?t supply fuel. I plan on switching the fittings to Johnson/Evinrude, seeing I have that tank.
What year is this?
The Impler number?
And the Big One!
