Chrysler 3.6hp recoil
shep65
Hi,
I have a Chrysler 3.6 hp outboard. The recoil starter engages poorly / not at all. I've looked inside the recoil unit, and the "starter cup / ring" is worn to a point where the pawls do not grip when the cord is pulled. Does anybody know where to get spares in the UK please?
As far as I can make out the numbers on the engine are 320C & 4085. Don't know year of manufacture. Grateful if anybody can advise.
Thanks,
Shep65
jerryjerry05
Re: Chrysler 3.6hp recoil
Picture of the motor would help as those #s don't mean much.J
CaptainHook
I have a 6 hp chrysler that I am going to part out. If it is the same I may be able to help you out......
shep65
Thanks for replies guys, I've attached some pictures.
Outside sia of cup = 73mm
inside dia = 50mm
internal depth = 32mm
external depth = 35mm.
rechecked model number using magnifying glass, it's 32HC, which as far as I can find from this site, http://www.maxrules.com/ChryslerModels/3p5_9p2.html
is a 1974 to 1977 model, ser no is 4085.
Thanks,
Shep65.
