Chrysler 55 sparks once then dosent
rich201283
I have a chrysler 55 magnapower model:559h9l serial:4651 with the electronic ignition that wont start, i have taken the plugs out and earthed them to check for a spark and it sparks once then doesnt spark again after that untill i turn it over again, has anyone got any ideas what could be causing this problem?
eurolarva
Re: Chrysler 55 sparks once then dosent
When you say you are earthing them does that mean you are grounding them to the motor? I like to use a vise grips to the threads and clamped to the metal on the motor. Test for the spark in a dark place like your garage. Make sure you have muffs on or motor is in a test tank so you dont burn out your impeller.
rich201283
