chrysler 55
jon_jon_8
starts and runs good shut down after two hours will not start four 4 to 5 hours not elect have changed points coll plugs
roscoe
Re: chrysler 55
How many times has this happened? Just once, or many times? What was the weather like when it did this? Please post more details of motor, year, model, etc.
steelespike
Re: chrysler 55
You should be working with a manual.<br />Have you checked the kill switch?Is there spark?<br /> If Im reading my manual correctly the motor could have one of 2 types of ignition.Standard magneto with points or cdi with points and external coils. I believe the mag.uses a kill switch.The cdi uses 12 volts from the battery via the key switch..Check for 12 volts at the cdi with the key on.<br /> When checking for spark you should use a plug with the the ground electrodes removed and well grounded or the cdi may be damaged.
