Chrysler 6 - no spark
twocyclemania
I just picked up a (79-82? Model 64H9E) 6 horse Chrysler. The motor was used twice. It looks like it just left the factory; however I have no spark. I'm not familiar with the Chrysler ignition systems. I haven't 'popped' the flywheel yet as I'm hoping for some advice before I even get started. I noticed that there are virtually no coils (my first suspect) available. I noticed that there's also something called a 'trigger.' Any ideas on what to suspect, what to do and where to find the parts? thanks
jerryjerry05
Re: Chrysler 6 - no spark
Is it a points or electronic ignition?Post a couple of pics of the coils or power packs?
Sounds like the points are corroded.You'll have to take off the flywheel and clean the contacts.J
twocyclemania
Thanks Captain jerryjerry05: You were right on the money. I popped the flywheel and 'dressed' the points (it has points, condensers and coils). I got spark at both cylinders and fired it up in two pulls. Everything under the flywheel looked like new. Thanks again!
economate2
Could you please explain what exactly you found the problem to be and how you fixed it? I have the same model motor and also have no spark. I took off the flywheel and don't know what I'm looking at or what to do. Everything looks to be alright, but I still don't have a spark in either plug.
