las
Thread starter- Joined
- Sep 22, 2014
- 165
Hi folks, took the old Selco and Chrysler 65hp out sailing for the first time in 5 years after getting interested in boating again.
I had just received a NOS SS propeller, a 10x14 cupped Michigan wheels and mounted it up and went for a test.
Out of the harbour and accelerating the whole engine jolted and it seemed like a severe backfire. I thought it might needed to run and heat up a little but then i continued and i headed back.
The last few hundred meters it actually got worse even though I hardly gave it any throttle, to the point were it wouldn't move forward. And it was at that point I knew it wasn't a misfire, but a gear issue.
I continued to adjust the gear linkage and play in the system for the rest of the day, but I already knew what had happened and the damage had already been done.
Today I decided to open the gearcase up and see what it looked like, and if it was possible to fix or even to dismantle it without destroying the engine.
I think there's a rather fine line with these engines when to call it quits. And after the last outing I knew I wouldn't trust it not to skip gears on the water unless i opened it up and fixed it or killed it trying.
But at the end of the day I managed to dismantle it without to much damage, or so it seems!
I can tell you right away that it's not a job for the average DIY'er.
At this point there's still hope for the engine.... But the next few days will show i guess!
Tomorrow I will get some pictures uploaded and share some thoughts and maybe get a few pieces of advice.
Well actually I already have some thoughts regarding the lower leg. Before going sailing I gave the gear some fresh gear oil and after disassembling it I saw there was some bronze bushings in there and I know newer gear oil will damage them! I can't remember right now how it is, but it's worth having in mind when it's time to put it back together.
