chrysler 6hp carb options
:confused:im building a single seat mini boat out of a dead seadoo and a 60s chrysler 6hp but my motor has no carb i was thinking about useing a kehin dirtbike carb with the same bolt pattern i got in my shop but i dont know how these motors pump gas to the carb and i dont want to mount a tank on top the motor:confused:
jerryjerry05
Re: chrysler 6hp carb options
Usually the 6 had a tank on top?Some way older models had a pump as part of the carb.
There anything like a pump on the motor?
Post a pic of the motor/both sides and front.
Model and serial#s will help too.valleysales@charter.net Valley 989) 366-8178 Sales This guy has a bunch of older Chryslers.J
Frank Acampora
The six is a two cylinder water cooled engine. It has a small fuel pump located at the top of the bypass covers. If you can attach the linkage and if the carb has a float, then it should work.
thanks is there anyway to get anymore power out of this motor the guy i got the motor from has a massive outboard part stash and does drilling the pipe help or cause problems
Frank Acampora
Let's get real! Yeah, you can port it and develop more power but realistically, how much can you expect? 7 HP? 8 HP? Want more power? Cheaper and easier to buy a used 9.9. Face it--these engines were designed as basic power plants to get you from point A to point B. Basic small hull fishing engines.
Drilling the pipe? there is no pipe to speak of. Exhaust gases pass down the leg and out the snout. very little restriction there. You can make and install a 1/4 to 1/2 inch thick plate to space out the exhaust cover, thereby increasing exhaust chest volume for --oh, on that engine, 1/4 to 1/2 HP more. But is it really worth it?
