Re: Chrysler 6hp outboard
The basics are to rebuild carb and fuel pump if it has one. Also new plugs, new fuel lines. Can do all this for about 25 bucks. Then drain and re fill lower unit with new oil. Might not hurt to squirt some oil into the cylinders and crank on it a couple of times to loosen it up in there. Most important is get a manual. It will make it a lot easier when you start taking stuff apart.<br /><br />Oh yeah. If it has an external gas can you might want to get a new plastic one. If not try flushing out gas tank with gas and drain into a glass mason jar and check for debris
