1978Galaxie
Thread starter- Joined
- Nov 25, 2017
- 17
At wot the boat seems to lack power and it also seems to ping a little bit too. I just rebuilt the carburetors this spring. It seems when setting the idle, even with the idle speed screw on the timing tower not touching the block, and pushing it in, the side of the rod hits the block, it still seems to idle high. I pressure tested the crank case for leaks, and I’m hearing air hissing out of that opening in the lower unit. Is there some kind of vent that’s supposed to be there? Or is that where my crankcase leak is at? The timing was at 39 degrees btdc at wot, and I’ve adjusted it to 32. This boat is a 1978 Galaxie with a 757h8c motor I believe.
