Re: Chrysler '79 70 hp 3 carb tuning
Hmmm! Maybe I need to modify that post.
At the control box, the cable should be about 1/2 way into the circular "pin" with a 10-32 nut securing it from backing out. Then, the cable sheath should be secured into the pivot in the center of the box, NOT one of the legs. Be sure the groove in the ferrule is snapped in properly. Only the gearshift cable is secured in the leg if it is a hidden box (almost square)or the box case if it a surface mount (Rectangular.)
BTW: There are two legs or two holes in the box to allow flipping it over for use on the opposite side of the boat. Same thing with the holes in the shift lever. And the control handle may be adjusted infinitely on its splined shaft.
The adjustment at the engine should have a large spring loaded (cylinder) end for the throttle. It is screwed onto the cable so that in neutral about 1/4 inch of the spring loaded center is pulled out. This allows shifting before the throttle starts to advance. If both cable ends are the same and only about one inch long, then the throttle cable has the incorrect end. Adjustment will be difficult.
At the engine, you should be sure that the groove in the ferrule at the cable end is secured in the clamp. NOW, you should be able to correctly adjust the carb opening at full throttle and still have correct cam position at idle. NOTE that changing the idle speed with the stop screw will change the position of the mark on the cam.
The distributor is first adjusted to top dead center. With the flywheel at top dead center, the pulley on the distributor should have the curved groove matching the curve of the flywheel with the center straight line pointing straight at the flywheel. To change pulley position loosen the two 9/16 head bolts and loosen the distributor so the belt can be moved. After setting the pulley, pull out the distributor ONLY until the belt will deflect about 3/16 inch when pushed in the center with an .010 feeler gauge and tighten the bolts. Timing belt too loose and timing will flutter a bit. Too tight and the engine will bind going into and coming out of gear. Now the distributor matches the flywheel position.
Timing can be done static on these engines by turning the flywheel by hand with the ignition on. Be sure all the plugs are out and grounded so the damn thing doesn't fire and put you in the nine finger club.
The distributor is held in position by two black plastic pieces joined by a threaded rod. You loosen the locknut and turn the threaded rod to open or close the gap between the plastic pieces, thereby retarding or advancing timing.
Once you have set the cam and roller on the throttle, when the engine is correctly set-up and idling, the marks on the cam will NOT touch the roller but will be slightly below it.
Hope that helps a little more.
