Hi. I'm only new to using forums so hope I'm doing it right. I have owned a 1973 Chrysler 120HP outboard for many years. The last few times I've used my boat, the boat well at the back of the boat has had a large amount of what looks to be oil/fuel mix with water that has turned into a yellow oily liquid. It is also on the leg of the outboard after I get it out of the water after a few minutes. It just seems to seep out. It isn't gearbox oil as the gearbox oil is clean with no water in it. The engine runs fine and starts on the first click every time I use it, even if I haven't used my boat for over a year. If anyone can help with where this oily mixture is coming from and how to fix it, I would be greatful. Thank you, George
