Frank Acampora
- Joined
- Jan 19, 2007
- 12,004
Re: Chrysler Project Motor
The rotor and shaft are an assembly, epoxied together and not serviceable. You must replace the shaft, cam, and rotor.
The pulley can be held with a cloth over the belt and a water pump pliers to hold it. The top nut is nylock and while tight, it will come off rather easily after it is broken free. The pulley is a tight clearance fit on the shaft, held in place with a woodruff key. It slides straight up off the shaft.
Since the drive dogsmust have clearance to properly engage while rotating, In gear, the prop will turn about 30 degrees either way. This may seem excessive, but is completely normal.
Don't bother removing the distributor from the mount now that it seems to be functioning smoothly.
Props are usually matched to the hull and engine. There is not a lot of choice for these engines. Just go by the general guides I wrot in an earlier answer.
