chrysler recoil starter
seahunter69
hi i have a mid 70s chrysler 15 hp outboard that runs well, the only problem is that there is no recoil or electric start
taking the hood and wrapping a rope round the flywheel is getting a little tiring
could any one help photos of starters or part numbers would help alot
thanks
Frank Acampora
Re: chrysler recoil starter
That recoil starter was used on Chrysler 8, 9.9 through 15 and Force 9.9 possibly through 15 engines so you have a lot of engines and years to choose from.
They come up on ebay periodically but are expensive for a used part, usually selling for around 30 bucks or more.
If you can find a whole junk engine to salvage one from, that would be the way to go since I am sure that a new assembly would go well over 60 bucks.
The assembly consists of a top bracket and a bottom bracket that bolt to the engine using two bolts each, plastic a rope spool, rope and handle, a plastic idler pulley, an internal rewind spring, and a plastic bendix gear. You know the dealer will hurt you and leave you walking funny if you buy a new assembly.
There is also an interlock to prevent starting in gear but that assembly is not necessary--the starter will work without it. If you have it, use it. If not----the decision is yours.
seahunter69
thanks for that. do you think that johnson type starters with a modified bendix may work.
duaneiver
I have a 12.9 chrysler, and would like to find a new plastic pinion gear for the recoil starter. Does anyone have any suggestions? thank you, dij1962@live.com
charlie-o
Seahunter 69 and Duaneiver
I just recently ordered new parts for recoil starter for 1982 Chrysler 15 hp from Quicksilver.com division of Mercury Motors. They have parts in stock. from charlie-o
charlie-o
Gentlemen, Can someone tell me how to set the tension on recoil spring on pull start. Motor is a 1982 Montgomery Ward (Chrysler).
15-HP at 5100-rpm
Model # VWB-52119-C
Serial # 28-X-25123
Bought new parts but can't figure how to retension the spring. Any help will be appreciated.
