wakeandsky
Thread starter- Joined
- Aug 24, 2008
- 3
My father has a 35HP model 357HE s/n 3235. I maintain it for him and drive it basically twice a year - to put it in and take it out, so when it has problems, I'm not there to witness what happened. Last year it stalled out and my father had it towed to a shop and they said all they did was clean the carb. it finished the season without a problem. At the start of this season it ran fine, but stalled out within a couple of days. I found the carb bowl to have a fair amount of small black particles in it, so I cleaned it out and sprayed down the rest of the carb and sent it on it's merry way. Same thing happened (again, I was never with the boat when these things occured) so I totally disassembled and cleaned the carb, tweeked its settings and it ran like when he first got it. The following day I got the call that it had stalled out again. I thought the bowl gasket might be deteriating so I order a gasket kit, cleaned the carb again, replaced the gas lines, cleaned the tanks, and put in inline filter. Went to start it and of course the battery was dead from people trying to restart it. Charged the battery to the point of being able to restart the engine. Ran the engine for about 15 minutes. Took it out for a run. All seemed ok until I was coming back in, slowed the engine, it sputtered and died. Battery was too low to restart, so I dragged it back to the dock, poppped the charger on and a couple of minutes later it fired up fine. Ran it for a half an hour and then started getting intermittent sputtering and a couple of stalls. I'm perplexed because I haven't found a consistent pattern. Once it seemed like it was running on 1 cylinder and within 30 seconds it was back to normal. Other times it just sputters and dies. I thought it might be overheating, but the head doesn't seem very hot and I'm getting a decent telltale. I have a float on order, but haven't gotten it yet, but it didn't seem to be shedding particles. I've thought it might be the fuel pump, but I wouldn't think I should be able to go for a half hour of operation without a problem and then have it clear up in a few moments. Any thoughts?
