clanging in prop
comet424
oh another issue just showed up not sure if its bad or if that's normal I just spun the prop by hand and there is a clanging sound is that normal???
here is a link to my video of the prop
http://youtu.be/HaS2gh6ZG54
but if I spin the prop other way doesn't clang loud
Frank Acampora
The shift linkage is not correctly centered and you are hearing the drive dogs tapping each other.
comet424
oh so how do I fix that is that adjustment at the engine?? or at the control
I know the throttle control at the front only go up to fuel saver mark but not all the way forward not sure how to fix that either
comet424
nvm I figured it out its that center rod of the engine where its hard to get at I adjused the lower nut about 3/4 of a turn or less and then tightened the top lock nut down.. no more clanging. I think engine is ready to go in the water instead of just in the box so I can adjust the forward idle
so when I push forward a bit it just shifts it into gear but doesn't adjust the idle speed.
is that where I adjust the idle speed to roughly 700-80 rpms where it just engages but it doesn't adjust the distrubtor movement
