Classic 45 Merc wont pump fuel consistantly FIXED!
imported_bowfisher
Heres the facts.... Mercury 4cylinder, 2 carb, fuel pump on the side of the carbs, 50 hp outboard
New fuel tank, new fuel line and bulb, new connector, rebuilt carbs and fuel pumps, all new fuel lines on motor except for one.
Motor starts easily, runs in the tank even at higher RPM. Put it on the water, pop in gear and get on the gas, motor bogs after a few seconds until the bulb is squeezed.
Could the new diaghrams been weak or at least one of them anyway? Appears to be NO restrictions anywhere to the carbs and the tank is vented, connection tight with no fuel leaks anywhere.
*Scratching my head*
Thanks!!
imported_bowfisher
Re: Classic 45 Merc wont pump fuel consistantly
Sorry, I forgot to mention, yes the carb gaskets are installed properly. Thanks!!
bgc
Ensign
What year is she?
imported_bowfisher
I would guess late 80's to early 90's without checking
BatDaddy1887
Maybe replace the fuel filter near the engine (if it has one) or replace the water separator filter (if it has one). Always put half-a-can of Seafoam in every other tankful or so to keep all parts clean as a whistle. I heard that Mercury outboard fuel line and bulbs are the best to get as the bulb has a flange on both ends instead of just one side.....
on_ice
How do the fuel pumps work? I have the same motor and I took the carbs apart today and it doesnt exactly seem like there is a fuel pump on the side of each carb. The manual states it does but I'm not convinced they are talking about the same motor.
on_ice
Are you setting the idle with it in gear and in a bucket of water? You need that resistance or else the engine will die once the extra resistance is there from the water.
BatDaddy1887
Here is where my fuel pump is located.
on_ice
Same with mine. Is that the 115 in your signature? I see you have the "A" carbs they have in the manual. Mine are no where to be found in the manual but somewhat resemble the "B" carbs.
imported_bowfisher
Here is what I found...... previous owner had the motor worked on at a marina, they replaced one of the carbs (why I have no idea) the carb that was replaced was not identical to the original. The replacement carb had a .05" main jet, the original had a .056. I removed the (replacement) and attached a carb with a .055 jet. Also replaced all fuel lines again just in case there was something I over looked. Boat now runs properly. Still not sure which fixed it but am pretty sure it was the jet size.
