Classic 50 fuel pump?
BrianVT
Trying to figure out why this engine won’t rev.
I suspect the fuel pump. But I don’t see one. Do these not have one or is it somehow located in the block under where the quick fuel connector comes into the lower cowl?
Honorary Supreme Mariner
Serial number required.-----On some of these the fuel pumps are on each carburetor.----On the later models there was one pump on the side of the block.----Look for / follow the hoses.
BrianVT
A959445
Thanks. I guess they must be in the carbs. on this one.
Not sure what else to try except checking for exhaust blockage.
Check compression post your numbers.----Test spark and see if it jumps an actual gap of 3/8" on a test device.-----Install a new impeller if motor is new to you and every 5 years.
BrianVT
130 lbs. compression on the 3 cylinders I can get at. Will check other suggestions. Thanks.
roscoe
Do you not have a fuel pump like this on the side of the block ?
If your serial number was lower than A710280, pump would be in the carb, like this.:
BrianVT
That looks like my carburetors. So I guess no fuel pump even though my # starts with 9.
I guess I'll replace the impeller and see what I find in there. I seems to pumping well so I'm not confident my engine problem will be found down there. But I do have a slight gear oil leak so it won't be a total waste of time and money.
