Classic 50 vro delete
superclarke
Hey everyone ....need some help. 1987 bass tracker with classic 50 45hp engine. Want to delete the vro but not sure what needs done. Watched tons of videos on vro deletion but none are like the system I have on my classic 50. The oil is premixed at the reservoir tank and then goes into the gas inlet hose on the engine. (Lots of videos show a oil hose going into the engine) I only have three wires that hook onto the engine, brown, black (I’m assuming a ground) and a purple one. I’ve already disconnected the electric fastener (it has these three wires)that goes to the oil sending unit as well as disconnecting the brown wire from the engine. What else do I need to do? Since I’ve already disconnected from the sending unit does the purple wire need disconnected from the engine also? I’m doing this because after replacing the water impeller, I got a constant buzzing noise that indicates the engine is either or heating or is not getting proper oil mixture. Just going to premix gas and make sure I’m not causing harm to the engine . Thanks , hope some of you can help
GilLesS72
Can you post a pic of where the oil gets mixed up before going into the bloc. Also attach some pics of the bloc itself where the fuel pump is.
