Classic Fifty ignition problem
Alex from GA
Like the title says I have an ignition problem. The last time I was troubleshooting a problem I saw a chart in CDI ignitions website with resistances and voltages for all Mercury engines. I had a '74 850. What I'm asking is where to find a chart with resistances and voltages for an '88 Classic Fifty. The top cylinder doesn't reduce RPMs when I pull the plug wire off, all the others do. Thanks
Honorary Supreme Mariner
So does the top wire have spark that will jump a gap of 3/8" , yes or no ?-----What happens when you switch # 1 and # 2 coils as a spark test ?
Alex from GA
Can I just change the coil wires or do I also have to change the power pack wires also. I would think the timing would be wrong if I only changed the coils. BTW I tried that yesterday and it only ran on 2, worse than before.
No need for motor to run when testing !!------You can just change wires from switchbox to the coils.----Just for testing to see if the ignition is capable of jumping a gap of 3/8"-------And testing is what is done to see what is wrong here.---Also do a compression test
merc850
I've seen a few posts about "Classic 50's" and I'd like to see a picture of one if someone would post one.
Called a " classic " since the design originated in the early 1950's-----A label attached in the hope that folks would keep buying it.------Good smooth runners .----Perhaps expensive to produce in the age of robot manufacturing.
Alex from GA
Went fishing today and the engine ran on all cylinders when it started. A compression check was 130-135 for all cylinders. Does anyone know where the idle and timing adjustments are. If it sat for over 1/2 hour it seemed to drain all the gas out of the carburetors and the bulb had to be pumped to start and it cranked for a long time. The carburetors were cleaned and the gaskets changed this week and the needles don't leak. 850 look on youtube for the Classic Fifty, there are many shown.
flyingscott
After a 1/2 hr of.sitting it is normal to have to use the cold.start procedure, this includes using the choke/primer. The ball does not stay hard all the time. Once the motor is running it willl goe soft.
