Re: clean hull with? primer issue and questions on easypoxy
Well it is flipped. Not with out issue but flipped.
When I got ready to lower it it fell about 6 to 10 inchs and landed in a rusty bumper.
Here is the damage caused. It is about an area 3 x 5
A little 1200 sand paper and poof its gone.
That hardener sure works good. The spot is a bit duller, but hey after I sand the sides with 1200 then polish after top cap is ready to polish it will be gone gone gone. :clap2:
Now when sanding around the hatch lids just a light touch with 80 grit should do right? Holes should be filled with epoxy with fibers and filler right? How to I plug the backside if I can not reach it to put a piece of tap in back of hole to keep PB from falling through?
