cleaning carburetor
cat25
at the end of the last season motor would stall at idle. neaby boatyard supposedly cleaned the carb. motor has run great all season this year until the very end and now stalling again.
don't have much mechanical experience with motors however is cleaning the carburetor something i could take on or best to leave to the boatyard?
any "cleaning the carb for dummies" info out there??
(honda 8HP 4stroke)
thanks
Sea Rider
Re: cleaning carburetor
It's nothing out of this world, put it back together as it was before servicing, the only issue, would need to remove air/gas screw to clean well inside passage, if engine has been running great at that given idle adjustment, with a caliper measure the height of the top screw to base, put same measurement after cleaning if you don't know how to tune engine at idle well, if correct idle rpm, leave as it is, no need to remove this crew. Consume all gas leftovers after use, keep engine on till it dies of fuel starvation.
Happy Boating
