Re: Cleaning Diamond Plated Tool Box
Some of the diamond plate boxes are then clear anodized to maintain the shine and if you use aluminum acid (concoil) on them, it will either be ineffective or ruin the clear coat. What you want is an industrial type detergent such as Simple Green or Purple Power, both should be readily available at any home improvement store. If it is not cleared, then the concoil should work great as will any acid based cleaner designed to be used on aluminum wheels. And if neither of those work then try wire wheel acid, it's a bit more aggressive, but if you are not careful it will turn your aluminum white.
Stan
