firemedicmonkey
Thread starter- Joined
- May 7, 2009
- 48
I got a 22ft Bayliner I am trying to get into shape after sitting for several 2-3yrs. I am sure it was not winterized properly so I know any gas in the tank is bad...
The plan: Drain the tank, change the fuel filter, drain and clean carb bowl, before firing.
The Question: I was at West Marine and saw some stuff that says it will fix bad gas and clean the gas tank! Does this stuff work? Should I use it? What else if anything should I do to clean the gas tank?
