Daniel1947
Thread starter- Joined
- Sep 22, 2010
- 267
[FONT="]I know there has to be a clearance between the stringers and the hull of approximately 1/4" (filled with 5200 or PB) to prevent hard spots.
My question is in regards to the outer section of my boat where the deck will be in contact with the hull, basically laying flat on the hull.
I can maintain clearance between the outer edges of the plywood and the outer sides of the hull. But, I am wondering if it is necessary to also maintain that clearance between the bottom of the plywood and top of the hull. My hull is completely flat for approximately 12 inches along the outer edge as I have attempted to illustrate. I do believe that the old deck was just laying flat on the hull along that 12 inches and tabbed in on the sides...I could be wrong. But I had no difficulty in removing the old deck along the outer edges after I cut through the tabbing on the outer edge. As always, I appreciate any and all reply's.[/FONT]
