shotgundexter
- Joined
- May 24, 2010
- 24
Battery is a year old, full charge and tested good. Starter clicks. My question is --if it was something like the fuse on the starter, would it even click. I would assume that it would be totally dead. The boat is a 99 Caravelle, with the 3.0 mercruiser outdrive. My plan is to remove the starter and have it tested. I suppose ill try cleaning all the connection points real good first. Tell me if anyone disagree's but at this point I am thinking bad ground connection, or my starter just went bad sitting over the winter. I would appreciate any input and any opinion on this problem. Part of my assumption is that the block looking thing that is attatched to the starter, near the battery wire is the high amp fuse I have seen mentioned in other posts. Thanks for reading.
