Re: Click at the starter, No crank. Good battery.
this test is direct battery to starter
The starter not spinning here leaves only two possibilities, battery or starter
I'm always suspicious of good testing batteries, was it taekn to an auto store and tested under load or simply tested 12+v on meter
At this point I would remove the starter from the boat and test with jumpre cables from different battery source, car etc.
You will connect negative to frame of starter
the positive to the post that connects the starter and starter solenoid (C)
If it spins, the battery then the boat battery is not "good" enough
If it does not spin it is the starter.
If it does spin...
Extra test to check starter solenoid. Instead of connecting positive to C, connect it to B, this should throw out the bendix as well as spin. If it does not, your starter solenoid is bad as well as your boat battery.
If it does spin...
