Click, Click... Starter is good but new Problem arises...
Status
Not open for further replies.
no luck
Well, starter is good. I pulled the drive and it was fine and yes it was easy to do.WOW!!!!! I sanded the top of the starter , torqued the ground bolt at the block and bought a new batt. fixed the points and it started right up but .......... I noticed A bit of water running down the side of the motor from under the manifold, right in the center/oil looks milky. How do i find out if its the head/head gasket or the block? It was running strong. HELP!!!!! and thx, NO LUCK.:confused:
Don S
Re: Click, Click... Starter is good but new Problem arises...
You added this same thing as a reply to your other post which has all the info.
Don't start a new thread on the same problem.
Status
