Clicking in foward - 50hp
bigdaddypt
Hi All,
I'm putting a 50hp Mercury (early 80s - 83 maybe) back on my grandfather's boat. It's been off since 2000. I've attached everything and just finished the cables. Before I attached the cables it was in neutral and the prop spun both ways like it should. I would click it into reverse and it would spin (along with the power head) properly. However, when I put it in forward, I'm hearing a clicking noise and the power head isn't turning. Same happened when I attached the cables.
Any thoughts?
Secondary, the serial number is 6224664. Anyone know the year?
Thank you in advance.
emoney
Re: Clicking in foward - 50hp
My 120hp does the same thing and works just fine. It's called a "ratcheting clutch dog"
bigdaddypt
Thanks for the quick response. I have a boat with a Merc I/O so this is a little new to me. So if/when I get it started, and put it in drive, I'll be ok?
Thanks again!
bigdaddypt
Got it running. Everything seems great. Thanks again.
Anyone know the year. Here's the serial # 6224664
