clicking starter assist solenoid
katt68
good day,
trying to start my boat was turning over then all of a sudden alli get is a clicking out of the assist solenoid. battery is good and charged, starter is fine....
how can i test this solenoid?
thanks in advance....
Re: starter assist solenoid, 3.0l cobra
good day,
Ayuh,.... Welcome Aboard,.... With a Jump Wire, from Big terminal, to Big terminal....
Check, 'n Clean the blocks Ground connections, 'n Both battery terminals too... Shiny metal Clean...
katt68
good day,
well, replaced the starter assist solenoid with a new one, cleaned all the grounds, checked connections....
still clicks when i turn the key.
what could be the issue here?
it is a 3.0l omc cobra
katt68
replaced solenoid, still clicks....any ideas?
HT32BSX115
Re: clicking starter assist solenoid
good day,
Howdy,
It could still be bad or you have a bad starter.
Get s simple test light and use it to find where the power is (or isn't) going.
Just replacing parts will get you nowhere. (except maybe a little poorer!)
Regards,
Rick
Ayuh,... Did you Clean, ALL the wiring ends,..??
Please don't keep startin' New threads on this subject,...
You have 1 thread goin',... Use it...
katt68
my solenoid only has 3 wires....which do i check?
Don S
That is because your slave solenoid grounds through the base instead of having the second small terminal for ground.
Ayuh,.... ALL of 'em...
1 big 1 will be 12v All the time...
The other big 1 is only Hot, when the little wire gets 12v from the keyswitch...
