clockwise or counter clockwise
blackz3
i just saw the impeller post was going to answer but thought better of it....i have an 88 5.7L merc alpha1 when i installed my impeller it seemed to be a little large so i had to turn it to get it in....now should the splines be bent clockwise or counterclockwise
Don S
Re: clockwise or counter clockwise
In a word, it doesn't matter. With the rubber vanes, they will turn with a new impeller and go in the proper direction, even if you put them in backwards. An old impeller that has taken a set may not turn around, but for all the work it takes, putting an old impeller back in is a big waste of time for the cost of an impeller.
Why'd you Bump your post z3 ?????<br /><br />I can't think of a Thing to add to Don's reply........<br /><br />Do you have Another Question ??
blackz3
because of the ALPHA1 IMPELLER post
trog100
praps the length of the vanes varies from one impellor to another.. the longer and more curled the vanes are the harder it would be for em to turn around if fitted the wrong way.. i just fitted a new impellor in an old chrysler 9.9 outboard and the vanes looked that long and curled it didnt look that they would turn easy if fitted the wrong way..<br /><br />i aint saying they wont turn.. just that in some instances they might get damaged while doing so..<br /><br />it clearly makes sense to fit them the right way around in the first place if the vanes look long and curled.. shorter less curled ones probably dont matter..<br /><br />trog100
