Is the old block off plate with two gaskets a good system for closed cooling? Do I use the Mercury permatex type gasket sealer on those? It costs me $20 a pop plus exhaust gaskets each time for new style and old style is cheaper. I can't even get at the spark plugs without removing the exhaust.
Has anyone ever welded the coolant holes shut and machined these surfaces between elbow and manifold? I wouldn't have to worry about water leakage at this joint if I did that just exhaust gas. Can I weld the cast iron with wire feeder? I was thinking of trying this on the old exhaust set.
(I didn't realize I had to become a Mercruiser mechanic to own one. I guess it is my own fault for buying a saltwater boat to save some money on Ebay. It will be a nice boat though, 1999 Sea Pro 235 WA for fishing Lake Superior.)
