hello all, i have a 84 merc 350i/o with alpha1 and closed cooling system.
problem loosing coolant from overflow reservoir(empty) into bilge, engine never overheated steady temps at 160-180.
parts replaced new t stat 160 degree, pressure cap 14psi, od water pump, engine water pump, exhaust manifolds and risers about 30hrs ago.
ignition timing set at 8btc idles at 650, new plugs wires and rotor thunderbolt iv ignition.
suspicion pressure cap psi too low. any ideas?
question can i run a higher psi like 16? would that cause the cooling system to over pressurize?
thanks for your time and replies.
