Glastron_V210
- Joined
- Jan 28, 2009
- 324
Re: closed cooling issue merc350i.o alpha1
If it's losing coolant, but not into the bilge, then the manifold/riser gaskets are the likely culprit. Use the acetone test to confirm. Or, renew the gaskets and reassemble and test. It could also be a heat exchanger internal leak, which will push coolant into the raw water flow. They are the big two leak points. To check the exchanger, pop off the end plates, block off the fresh water coolant passages and fill the passage with 10psi of air. Place the assembly in the bath tub full of water and look for bubbles. No bubbles, no leak.
After they are tight, then:
1) Assemble, but don't fill with coolant
2) Using the cap tester, fill the entire system to 10psi of air, then valve off
3) If the air pressure is maintained, you're good to go. If not, get snoop (leak detection fluid) or soapy water and check your hose connections. Check your thermostat gasket. Everything. Find, fix and repeat. If you can't find the leak externally, then it's either heat exchanger internal leak, head gasket or cracked head.
Now, you have a fair bit of confidence in your closed cooling system.
Fill er up and go for it.
Chay
Chay
