Closed cooling option?
rodbolt
Re: Closed cooling option?
someplace I recall reading a tech bulliten from merc about NOT freshwater cooling the inline manifolds,3.7 notwithstanding, due to cracking at the rear of the manifold.
its been tried by a few on this board and I dont think it was successfull and I dont think your pre-alpha seawater pump can flow enough to properly cool the heat exchanger if your cooling the manifold too.
starsnstripers
Yes Rodbolt they did have an issue with it and I found out on here by Don who put a post on about the reverse flow on that sysyem eliminates that problem. And iv'e read on several occasions that the outdrive water supply "if working properly and maintained" will have a sufficient water flow.;)
Ayuh,........ I think it was Chris,......... Not Don.......
Atleast the thread I participated in anyways....
starsnstripers
Yes my mistake I should have looked, it was Chris, I saved it for my reference Sorry Chris:redface: Thanks for clearafying that.;)
