- Joined
- Jul 18, 2011
- 19,600
In the time being . . . Here are a few more pictures that I have yet to post.
Temperature gauges at the helm when the engines are idling and brought up to temperature.
Here is one of the MEFI units (ECU) when I swapped them
The check sum label which is used to verify the program within the ECU.
IAC Valve . . .
Fuel Pressure Regulator . . .
Schrader Valve on fuel rail . . . the location of this valve makes it nearly impossible to check the fuel pressure while the engine is running . . . so I have done the 'static' testing with the fuel pressure gauge.
Under side of fuel rail where the regulator goes. This design was abandoned after a year or two in favor of a design where the regulator was located off the rail in a more accessible location.
It would be rather interesting if, after all of this fuss, it turned out to be the recirculating pump :facepalm:
IAC Valve . . .
