BOAT FOR SALE . . . BOAT FOR SALE
:facepalm:
I feel so defeated
I started out the day replacing the distributor and rotors. It turned out that one of the distributor cap screws was hanging on by a thread. When I went to fasten the new one down, the threads were completely stripped. :facepalm: Of course they are . . . why wouldn't they be
No, problem, I figured, I'll just put in a nut on the back of the distributor flange to hold that side down firmly. . . . Turns out that it is a #6 FINE pitch (40) thread
. . . I had none, all the stores in town had none :facepalm:
So, I spent a few hours trying to rig something up . . .
Anyway . . . onto the timing. I used the Diacom to set the engine(s) into base timing mode and I checked the timing. They were both dead nuts on 8 degrees BTDC
So, I tested the IAC's, which is just resetting them. That is when I got the error message on the port engine. The starboard engine 'passed' all of the tests.
I then replaced the Port IAC, figuring it was the problem. That's when I messed up putting things back together and the engine was revving high at idle. Once I got that sorted out the engine idled fine.
I then did another series of tests on the port engine and got the error message on all of them. So, I checked the connections on the MEFI . . . disconnected and reconnected the 2 big connectors and remounted the MEFI, figuring it might be a faulty case ground or something like that.
Still error messages on the Port MEFI while doing the tests.
One thing I have noticed is that the starbd engine MEFI gets 'discovered' right away by the Diacom, whereas the port engine takes a while. I'd say 2 seconds for the starbd engine and 15 seconds for the port engine.
I'm thinking it may be a connector issue on the Port MEFI. I could swap them pretty easily, so GOOD SUGGESTION . . . hadn't thought of that.
And due to all that fuss and confusion, I brought back a fairly full cooler of beer :facepalm:
