- Joined
- Jul 18, 2011
- 18,819
I have been loosing a small amount of coolant on the closed cooling systems of my engines this season. Not a lot of coolant loss, but enough to be adding a few ounces every other outing, etc.
Here are the engines with the SJE 'Full' closed cooling systems, which I have found to be awesome for salt water use.
So, now that the boat is out of the water of the season, I decided to run a cooling system pressure check to see if I can identify the source of the coolant loss/leaks. I drained the systems to do a pressure test with air, figuring that I could more easily 'hear' any leaks and use soapy water at the external joints and fittings to see any slow leaks.
I have a compressor and re-purposed a cylinder leak test gauge for the task.
I ran about 10 psi from the compressor and it took a minute or two to pressurize. I heard one leak that was fairly noticeable on the port engine . . . hose clamp not tight enough.
I also sprayed all of the external joints with soapy water to see if/where bubbles formed, indicating a leak. I found a couple of small leaks on each of the engines. Here is a picture of one of the supply hose/fitting joints at the exhaust manifold (they are part of the closed system). I found a few other locations like this one. So, a quick tightening of the hose clamps did the trick.
I did notice that the heat exchanger cap on the starboard engine has a leak under the outer seal. . . fairly in consequential, since it has an overflow reservoir.
It did make some nice bubbles though. . .
The good news is that I did not hear anything from inside the engine or the manifold /elbow joints. :thumb:
