whiskeyRichard
- Joined
- Sep 16, 2018
- 96
I recently purchased this boat and as is normal, it is going to put me through the paces with repairs.
It is a 1980 Mercruiser 260 I/O with a closed cooling system. The boat and engine have been well maintained.
After a few hours on the lake, there was A LOT of water in the bilge....hot water. It drained out the drain plug so I can only estimate, but I figure there was 20-30 gallons.....and apparently the bilge pump is not working either.
I am trying to figure out where the water is coming from. There is a little evidence of leakage around a couple fittings on the tube with the 90 brass fittings in the pictures, but certainly not enough to let that kind of water in. I have run it in the driveway for about 30 minutes with the motor in tank of water and never saw a drop.
I have checked the hull and there is no damage there that would allow water into the bilge.
I am guessing that I need to get around the rear of the motor and look around there while in the lake and running, but I figured I'd check here for some advice before I head out.
I have attached some pictures.
Thanks for any help,
wR
wR
